LabWindows/CVI
How do I implement mouseovers?
Newbie Question:
I would like to update a textbox control by simple mouseovering another control -- say for the sake of this example, a LED control. Is there way to do this?
Thanks in advance,
Mark
(3,766 Views)
Mark,
You can create mouseover events in LabWindows/CVI using the tooltip function panel. There is a Knowledge Base that describes this feature and also includes an example program.
See Can I use Tool Tips in LabWindows/CVI?
Note that this Tool Tips function panel is only available in LabWindows/CVI version 6.0.
(3,766 Views)
Mark,
Actually, the Tool Tips function panel is available in versions 5.5.1 of LabWindows/CVI and higher. Sorry about not being accurate at the start.
Shannon R
(3,766 Views)
