LabWindows/CVI
I have a PCI-DIO 96 and an external device that generates negative logic. How can I adapt the DAQ card to interpret this data?
I am inputing handshaked data from a group of two ports (0,1) configured using DIG_Scan_Setup.
(2,910 Views)
You cannot change the polarity of the handshaking lines for the DIO-96. One way around this is to have the external signal go through an inverter before it goes into the DIO-96.
If this will not work, you may want to consider getting a PCI-653x device which will allow you to change polarity of handshaking signals.
Brian
(2,910 Views)
