LabWindows/CVI
How do I programmatically generate a .tui file?
I am developing an application that will allow the user to configure the GUI during run-time. I would like to allow the user to save the gui set-up and recall it later. I don't think that SavePanelState and RecallPanelState are the correct answer because they do not save attribute information(like graph control size). I think that using the *.tui file maybe the right answer. I noticed the LoadPanel function can load from a *.tui file. How do I programmatically save panel and control attributes and values to a *.tui file?
(3,565 Views)
I assume you must be using the run-time movable controls instrument driver tool since it sounds like you are moving/sizing controls at runtime. The SavePanelState/RecallPanelState functions weren't designed to take into account design-time changes like movement of controls. Unfortunately, there isn't a way to do what you need built-in. What you would have to do is write your own data file to save off the position and sizes of the controls (using GetCtrlAttribute to get the sizes/positions) and read that in and reset all of the controls based on the sizes and positions in the file.
Best Regards,
Chris Matthews
(3,565 Views)
Thank you for your quick response. I was afraid that was going to be the answer. I quess it wont be that bad. I am going to move/size at runtime, but also plan on inserting and deleting controls during runtime. I am assumeing that would be not any (much) different that attributes.
(3,565 Views)
Yea, same story. You'll have to keep track of the new controls in your new file. I would just write a routine that looped through all currently existing controls (based on control constant) and saved off the size and position to a file.
Chris
(3,565 Views)
