LabWindows/CVI
How do I convert the values on the X-axis scale of my CVI graph from one unit to another (eg. from sample numbers to time)?
I have a graph in my CVI application which displays captured samples, with the X-axis being simply the sample number (e.g. 0 to 1000000). I need to convert this to a time representation, e.g. 0 to 1ms, but keeping the waveform on the graph the same. How can I do this?
(2,942 Views)
If you use the PlotWaveform function, there is a Initial X, and a X Increment that can be used to do this for a regular interval waveform. For example if you have 1000 points in an array that represents 1 second of time, then your X Increment would be 0.001, and your Initial X could be set to 0 or the starting time of the acquisition.
Best Regards,
Chris Matthews
(2,942 Views)
