LabWindows/CVI
How do I use a Active X server for LabVIEW with CVI
I need to controll AudioPrecision equipment (AP2722) thru CVI.
Audio Precision provides a Active X interface for LabVIEW (APIWIN.lib).
How can I use this from CVI.
(3,217 Views)
 Hi Rene,
There is a Create ActiveX Contoller Wizard in CVI.  This will take the ActiveX server that you were provided and create a wrapper around it so you will be able to use it in CVI.  The wizard can be accessed through Tool » Create ActiveX Controller.
Cheers,
Kelly R.
Applications Engineer
(3,192 Views)
