LabWindows/CVI
How modify Baud Rate in run-time mode without close the port?
In my application set COM port parameter using OpenComConfig function. When start the application (Run-Time mode) it's possible to modify Baud Rate parameter without close the port?
(3,170 Views)
The NI RS-232 comms library doesn't allow you to change the baud rate, number of data bits, stop bits, parity etc. unless you close the port and re-open it. If you need to do that, you will have to use the Windows API for communications instead.
This is a bit of a nuisance. I recently had to implement a protocol where the first byte of a message was indicated by being sent with a different parity, and the delay required to close and reopen the port between bytes using the NI libraries was unacceptable.
Martin.
Martin
Certified CVI Developer
(3,170 Views)
Hi Martin thanks for your answer.
Skull
(3,170 Views)
