LabWindows/CVI
How to Automatically select ignore button when Non-fatal pop-up error occured.
Just want to ask how to select "IGNORE" button programmatically when non-fatal error pop-up occurred. thanks.
(3,034 Views)
Accepted by kero06
You may check "ignore library Errors" for not displaying non fatal warnings messages from APIs being popped up.
(3,015 Views)
Thanks. BTW, I am referring to the error pop-up when the program is running. The error says that some thread was being used by other thread, wait until finished.
I will try your recommendation. Would like also to ask if I implemented this action, is the "FATAL ERROR" message pop-up will be not shown as well? I am worrying that the "FATAL ERROR" or some other error will not be shown once I check the "ignore library errors". All I want is only the "Non Fatal Error" pop-up message.
Thanks again for your support.
(3,001 Views)
This shall only affect the non fatal errors. The fatal error dialogues shall be still get popped up.
(2,980 Views)
