How to Build an LCVI App that Must Run by a User With Administrator Access
I would like to build my (LCVI 2009) application so that no one can run it unless they have administrator priveleges.  Can this be done?
If it's any help, I've attached a document that tells how to do this in Visual Studio.
Thanks.
(3,088 Views)
Accepted by Chopper77
Build >> Target Settings
enable the "Enable manifest file" option and browse to the manifest file you need.
PS: I can't remember if CVI 2009 has this option because I use CVI 2010
Vix
Using LV from 7
Using LW/CVI from 6.0
(3,080 Views)
Thank you!
(3,068 Views)
