LabWindows/CVI
How to I control the with of an colums in a table ?
I would like to auto size the width of the columns by the label of the columns.
thanks David
(2,897 Views)
You can use GetTextDisplaySize() to obtain the size in pixels of the column label text, and then set column width with SetTableColumnAttribute (panel, control, columnIdx, ATTR_COLUMN_WIDTH, value);
Roberto
(2,897 Views)
