LabWindows/CVI
How to acquire from various AI channels simultaneously with a different range for each one?
In LabView I have found some examples but in C there isn't seem to be any.
(4,677 Views)
One possibility is to create virtual channel in MAX, each with the appropriate range, and then programmatically add the channels to the acquisition task with DAQmxAddGlobalChansToTask
(4,667 Views)
Accepted by Franchesco
Or you can add channels one by one with individual instructions: the follwing code compile and runs with no errors on a vitual daq device:
err = DAQmxCreateTask ("", &taskH);
err = DAQmxCreateAIVoltageChan (taskH, "Dev1/ai0", "AI0", DAQmx_Val_Cfg_Default, -5.0, 5.0, DAQmx_Val_Volts, "");
err = DAQmxCreateAIVoltageChan (taskH, "Dev1/ai1", "AI1", DAQmx_Val_Cfg_Default, -10.0, 10.0, DAQmx_Val_Volts, "");
DAQmxStartTask (taskH);
err = DAQmxReadAnalogF64 (taskH, 5, 10.0, DAQmx_Val_GroupByChannel, val, 10, &read, 0);
DAQmxClearTask (taskH);
(4,664 Views)
