LabWindows/CVI
How to add a folder in Distribution kit
Hi..!
 I need to add a folder in my distribution kit...
 How can i do that..?
Thanx and regards,
Venki
(3,461 Views)
On my CVI 7 system, you just tick the "Relative Path" box, towards the bottom of the menu Build\Create Distribution Kit form, and enter the folder name. This will apply to the file group currently selected, installing those files into the location specified. (This procedure may be different for other versions of CVI.)
JR
Message Edited by jr_2005 on 01-31-2006 02:16 PM
(3,454 Views)
Hi Venki,
If you are talking about CVI 8.0, all the installed files and directories are in the lower portion of the Files tab.  You start out by picking a base installation location, like [Program Files], [Desktop], [System], etc. from the right-click menu's "All Install Locations" list. [Program Files] and [Start>>Programs] will already be visible by default.  Then you can build up subdirectory structure by selecting the base directory and hitting ctrl+N or selecting "New Subdirectory" from the right-click menu.
Hope this helps.
Mert A.
(3,437 Views)
