LabWindows/CVI
How to detect PCI card is available
HI,
My Requirement is when I start my program first of all it has to check PCI-6723 is Available or not in PCI Slot if the card is not available I have to popup a respective msg
How to check a card(xxxx) is available or not in PCI Slots.
Please send me one example ASAP
Waiting for reply
Regards
krishna
(3,276 Views)
I suggest you use at program start Ini_DA_Boards function to initialize your board: it the return code from this function is negative the board may be either not present or faulty, in both cases your application cannot start.
As usual, error value has a meaning that can obtained in a string using GetNIDAQErrorString function, so you can prompt your user with the exact description of the error.
(3,268 Views)
I am not sure how I got this code below. Probably I adapted a sample from the CVI distribution.
The code is made with (traditional) NI-DAQ. It consist of a function that returns a device type number for a NI-DAQ board. And I found a list of device type numbers in the help file for Traditional NI-DAQ C Function Reference Help with the description of Init_DA_Brds
Source:
#define BoardTypePci6110 241
#define BoardTypePci6111 244
static int previousBOLEstate; /* break on library errors */
And anywhere in your application:
    DeviceType = Log611xSearchBoard(BoardType);
    if (DeviceType >= 0)
        Log611xDevice = DeviceType;
        Init_DA_Brds(Log611xDevice, &BoardType);
        Timeout_Config(Log611xDevice, 60);
        switch (BoardType)
         case BoardTypePci6110:
            Log611xNumberChannels = 4;
            break;
         case BoardTypePci6111:
            Log611xNumberChannels = 2;
            break;
         default:
            Log611xNumberChannels = 0;
            break;
And the search function itself:
short Log611xSearchBoard(int type)
    unsigned short i=0;
    unsigned short status;
    unsigned long DT;
    short ReturnValue = -1;
    int Found = 0;
    previousBOLEstate = GetBreakOnLibraryErrors ();
    if (previousBOLEstate) DisableBreakOnLibraryErrors();
    while ((i<8) && (Found == 0))
        i += 1;
        status = Get_DAQ_Device_Info (i, ND_DEVICE_TYPE_CODE, &DT);
        if ((status == 0) && (DT == (unsigned long)type))
            Found = 1;
            ReturnValue = (short)i;
    if (previousBOLEstate)EnableBreakOnLibraryErrors();
    return(ReturnValue);
(3,266 Views)
