09-26-2011 11:44 PM
Hi everybody,
I build a distribution package under LW 8.0 in a PC(Agilent VISA is primary), then I install the distribution package in another PC.
But I found the distribution package install NI VISA as primary in another PC. So How could I make Agilent VISA as primary when I build Distribution Package?
Does anyone can help me?
09-29-2011 11:29 PM
Does anyone come into my situnation? Need your help.
10-06-2011 10:03 AM
TaoZ,
Does your application use both NI-VISA and Agilent VISA? NI-VISA is only functional as the primary VISA, so if you need to use both NI-VISA and Agilent VISA, Agilent VISA will need to be secondary. If you are using just Agilent VISA, then you should not need to install NI-VISA. If you already have NI-VISA installed on the system, then typically Agilent VISA will overwrite NI-VISA because they use higher version numbers than us, but this is not necessarily always the case. Which version of each driver are you working with?
