How to capture a .gif file from a spectrum analyzer and save the file in PC
I want to capture a .gif file from a spectrum analyzer and save the file in PC, but I've got a problem when read data from the instrument. I'm not sure how to format the string got from the instrument , When I use "%s" or "%t" as the read string format the data got from the instrument is truncated.
my code are as follows, could anyone tell me where i am wrong?
char resultsArray[5000];
viPrintf(hSpectrumInstr, ":MMEM:STOR:SCR 'C:PICTURE.GIF'\n");
 viQueryf(hSpectrumInstr, ":MMEM:DATA? 'C:PICTURE.GIF'\n", "%t", resultsArray);
 printf("%s", resultsArray);
 getchar();
Message 1 of 12
(5,815 Views)
For raw / binary data you might try the %b or %y specifier, see here
Message 2 of 12
(5,814 Views)
Hi wolfgang
it seemed that %b or %y is not accepted by the read string format. the run-time error is like this:
NON-FATAL RUN-TIME ERROR
"Spectrum Alnalyzer.c",line 29, col 5, thread id 0x00004284
Function viQueryf: (return value == -1073807297 [0xbfff003f])
the string format modifier is not valid.
Message 3 of 12
(5,810 Views)
forgot to tell , my spectrum analyzer is Agilent E4447,  is it possible that the string format for this instrument is not the same as the specifier mentioned in "Using VISA Formatted I/O in Instrument Driver Development"?
Message 4 of 12
(5,805 Views)
So how is your modifier? Can you post the relevant line?
Message 5 of 12
(5,804 Views)
viQueryf(hSpectrumInstr, ":MMEM:DATA? 'C:PICTURE.GIF'\n", "%b", resultsArray);
Message 6 of 12
(5,802 Views)
Accepted by pauline01
as you may see your code is unreadable, can you post a screenshot or, as before, a Word document?
When using '%b' the array should be of type ViInt8
Message 7 of 12
(5,800 Views)
sorry so late to reply,  my code is in the following word:
Message 8 of 12
(5,766 Views)
did you try declaring your array as type ViInt8 ?
Message 9 of 12
(5,753 Views)
Yes, I've tried declaring the variable 'resultArray' to ViInt8,  it also doesn't  work. It's strange the "%b" and "%y" are declared invalid for the string format modifier. I used the NI Max to communicate with the analyzer, it can read back correct data, so i think  my code relevant with capture pic probablly has problem.
Message 10 of 12
(5,747 Views)
