How to change WFMdoubleBuf.C to get two different analog outputs?
I changed the example coming with NI-DAQ 7.3, WFMdoubleBuf.C (please see the attachment), to generate two analog voltage outputs for channel 0 and 1 (PCI-6110). I got the signal, but the two outputs are the same. I guess the reason is they belong to the same group.
How can I get two different outputs (different amplitudes, phases and frequencies) by changing this program? Or is there any other ways?
Thank you very much!
Yong Xia
(2,964 Views)
Hi Yong,
Check out this example:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3E72F56A4E034080020E74861&p_node=DZ52337&p_source=External
It does simultaneous analog output on two channels. I think this may be just what you are looking for!!
Sal
(2,964 Views)
Hi, Salvador:
Thank you. Could you please see the attachment? I modified the example to 2 outputs and 1 input.
The problem is I can only see the outputs for a second if I keep the value of NORMAL_MODE as 0. Then I get some error information.
If I change the value of NORMAL_MODE from 0 to 1, the outputs can last till the ITERATIONS finished. Then I get the same error information:
NON-FATAL RUN-TIME ERROR: "AIAO_Sychronize.c", line 156, col 18, thread id 0x00000758: Function WFM_DB_HalfReady: (return value == -10608 [0xffffd690]). noTransferInProgError: No transfer is in progress for the specified resource.
1. I think the value of NORMAL_MODE should be 0.
2. It seems that the outputs can start without the starting of AI, I mean, without
any signal to my sensor, i.e. the input.
Could you please throw some light on these problems?
Yong
(2,964 Views)
