Hi, Salvador:
Thank you. Could you please see the attachment? I modified the example to 2 outputs and 1 input.
The problem is I can only see the outputs for a second if I keep the value of NORMAL_MODE as 0. Then I get some error information.
If I change the value of NORMAL_MODE from 0 to 1, the outputs can last till the ITERATIONS finished. Then I get the same error information:
NON-FATAL RUN-TIME ERROR: "AIAO_Sychronize.c", line 156, col 18, thread id 0x00000758: Function WFM_DB_HalfReady: (return value == -10608 [0xffffd690]). noTransferInProgError: No transfer is in progress for the specified resource.
1. I think the value of NORMAL_MODE should be 0.
2. It seems that the outputs can start without the starting of AI, I mean, without
any signal to my sensor, i.e. the input.
Could you please throw some light on these problems?
Yong
