LabWindows/CVI
How to change title bar color in windows style panel
I have a panel, in a windows style, and I want to change the default color (blue) to something else.
I see the 'Title Background Color' and the 'Title Color' are grayed out in properties under 'Title and Titlebar Appearance'.
Is there anyway I can change that blue to some other color?
Message 1 of 12
(8,867 Views)
Those attributes are valid for child panels only.
See the list of panel attributes.
S. Eren BALCI
IMESTEK
Message 2 of 12
(8,866 Views)
So how does one go about making a 'panel' a child of another panel, or a child panel alone?
It seems all the panels I create have the attributes greyed out that I need.
Message 3 of 12
(8,840 Views)
A child panel alone is a contradiction Smiley Wink
You define a panel as a child one by passing the handle of an existing panel to LoadPanel
See an example in your CVI samples folder called panels.prj
Message 4 of 12
(8,837 Views)
Isn't that done at run time? How can this be done and seen in the panel editor?
Message 5 of 12
(8,834 Views)
Unfortunately it can only be set at runtime. There is no setting in the panel editor.
S. Eren BALCI
IMESTEK
Message 6 of 12
(8,826 Views)
To be a bit more precise, the aspect of the panel (titlebar and frame style) you see in the editor is the one it will have if loaded as a child. When loaded as a top-level panel it will follow the Windows theme active in your system.
Message 7 of 12
(8,817 Views)
OK so I tried setting the title bar color on a child panel and am getting a error of "Library function error (return vaule == -46[0xffffffd2]). The attribute passed is not valid".
I'm using the following code:
        int bChildPanel   = NULL;
        int nStatus = 0;
        // load panel
        bChildPanel   = LoadPanel (bMainPanel, "test.uir", MYCHILD_PANEL);
        nStatus = SetCtrlAttribute(bChildPanel, MYCHILD_PANEL,  ATTR_TITLE_BACKCOLOR,  VAL_DK_GRAY);
Any suggestions?
Message 8 of 12
(8,801 Views)
Just tried with panels.prj example in CVI2012.
I never receive the error you are getting; nevertheless, the titlebar color attribute is honoured only if the title bar style is set to "Classic"
This is how it looks: note the different style for the titlebar:
I suggest you experiment with the sample project as I have done, and then compare your actual code with that of the example.
Message 9 of 12
(8,782 Views)
As per your suggestion I loaded the panels.prj into my Labwindows 2010 enviroment added the 'SetCtrlAttribute' and now am getting the following error:
"NON-FATAL RUN-TIME ERROR:   "panels.c", line 45, col 5, thread id 0x00001DF8:   Library function error (return value == -13 [0xfffffff3]). Invalid control ID"
I only added one line, see snippet below:
   hparent = LoadPanel (0, "panels.uir", PARENT);
    g_hchild1 = LoadPanel (hparent, "panels.uir", CHILD1);
    g_hgrandchild1 = LoadPanel (g_hchild1, "panels.uir", GRNDCHILD1);
    g_hchild2 = LoadPanel (hparent, "panels.uir", CHILD2);
    g_hgrandchild2 = LoadPanel (g_hchild2, "panels.uir", GRNDCHILD2);
    SetCtrlAttribute(g_hchild1, CHILD1, ATTR_TITLE_BACKCOLOR, VAL_DK_GRAY);
Any clues as to why I'm getting the above mentioned error from the 'SetCtrlAttribute' call"
Message 10 of 12
(8,769 Views)
