LabWindows/CVI
SetMouseCursor not working
Hello -
I'm trying to use SetMouseCursor to switch to VAL_HOUR_GLASS_CURSOR during a file processing operation that takes a few seconds. For some reason, the cursor appearance never changes from the default cursor. The operation is initiated by a button "commit" event, and the callback looks something like this:
int CVICALLBACK buttonCallback (int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
    switch (event)
        case EVENT_COMMIT:
            SetMouseCursor(VAL_HOUR_GLASS_CURSOR);
            // Do the file processing here...
            SetMouseCursor(VAL_DEFAULT_CURSOR);
            break;
    return 0;
I've also tried using SetPanelAttribute(panel, ATTR_MOUSE_CURSOR, ...) with the same results. The callback definitely executes, as the file processing works as expected - I just don't see the cursor change for some reason.
I'm using LabWindows CVI 2012 SP1, running under Windows 7. Thanks in advance!
Barry Wealand
(5,370 Views)
Can you try SetWaitCursor(1) and SetWaitCursor(0) first?
If that does not work try calling ProcessDrawEvents() after changing the cursor.
S. Eren BALCI
IMESTEK
(5,367 Views)
SetWaitCursor() seems to work fine. Thanks for the assist!  --Barry
(5,363 Views)
Great..! Nice to hear it worked.
Do not forget to mark the post as accepted solution.
Have a nice day 😉
S. Eren BALCI
IMESTEK
(5,361 Views)
