LabWindows/CVI
How to comunicate with a VSI thru Class 2
Hi, somebody has a example of how to use thew DG-VSI?
Thanks.
(2,810 Views)
Hi Wilbert,
I have not ever used that piece of hardware, but for most devices like this, the manufacturer will provide a driver and a set of functions to be used to control it.  You can make calls into their dll or driver from CVI.  CVI is a C compiler, so anything written in C or any C function calls will work.
Hope this helps!
john m
(2,796 Views)
