LabWindows/CVI
Why doesn't my CVI's panel's title bar text show up in Windows' Task Bar?
When I call
SetPanelAttribute (panel, ATTR_TITLE, sPanelTitle);
...that changes my CVI's panel's title bar, but the text in Windows' Task Bar is unchanged. Is there a separate function call for setting the Task Bar's text?
(3,387 Views)
You can set it at build time in the "Application Title" field on the Build->Target Settings menu.
JR
(3,382 Views)
Can the Task Bar text be set dynamically?
My program is basically a timer, and I want the "time remaining" to be visible on Windows' Task Bar as my program is running.
(3,370 Views)
Yes - use ATTR_TASKBAR_BUTTON_TEXT, with the SetSystemAttribute() function.
JR
(3,368 Views)
That works perfectly, thanks.
It works only when I make an executable, not during development, which is OK with me.
(3,358 Views)
