‎01-27-2023 03:59 PM
I am sure there is likely a simple answer, but I made the mistake of "releasing" the Build Options window when trying to release a header file. I can't figure out how to put the Build Options window back in place as the menu option that is used for other windows is lacking on the build output window.
Greg
Solved! Go to Solution.
‎01-28-2023 03:58 AM
It must be like me, it doesn't like being confined... 😅
More seriously, just right-click on the white of the window (not the bar) and select [Confine Window].
