LabWindows/CVI
redefinition error with loops
In some of my CVI projects, I get the following error:
error: redefinition of 'i'
This is for two loops that have the same local variable name, both inside a function call like this:
fdsdfdsfda
function(void)
  for (int i=0; i<1000; i++)
  for (int i=0; i<10000; i++)
Now here's the catch!  This same code is identical in other CVI projects, where I don't get that error.  Seems like a Build Options issue, right?  But I can't find a difference between the two projects.
Message 1 of 1
(1,429 Views)
