LabWindows/CVI
How to convert a negative "signed short int" into an array of two "char"?
I'm having difficulties to convert an signed short int (2byte) into an array of two chars.
My current try is like this:
void ConvertShortIntToByteArray(short int value)
unsigned char byteHi = 0x00; // High Byte of result
unsigned char byteLo =0x00; // Low Byte of result
unsigned char C1 = 0x00;
unsigned char C2 = 0x00;
unsigned char C3 = 0x00;
unsigned char C4 = 0x00;
short int tempValue = 0;
C4 = value % 16;
tempValue = value / 16;
C3 = tempValue % 16;
tempValue /= 16;
C2 = tempValue % 16;
tempValue /= 16;
C1 = tempValue % 16;
byteHi = C1 << 4;
byteHi += C2;
byteLo = C3 << 4;
byteLo += C4;
 It works OK for positive values (for example saying that 240 = 0x00 F0) but negative values don't work here.
Is there a way to convert signed short int values to a two byte array in a more easy way?
I know the correct way could be to go over binary like this:
Assume value = -240:
So abs(-240) = 240 = 00 F0 = 0000 0000 1111 0000
One-Complement:
1111 1111 0000 1111
Add '1' to the One-Complement:
1111 1111 0000 1111
+0000 0000 0000 0001
1111 1111 0001 0000
Result = 1111 1111 0001 0000 = FF 10 = -240
 But isn't there a more easy way that doesn't have to go over binary to achieve this?
Any help is greatly appreciated.
Thank you and best regards,
Bernd
(6,031 Views)
Accepted by topic author BerndSchoelzel
If you want to just let C do its thing:
void ConvertShortIntToByteArray(short int value) { unsigned char byteHi = value >> 8; // High Byte of result unsigned char byteLo = value; // Low Byte of result }
Or perhaps a little more understandably:
void ConvertShortIntToByteArray(short int value) { unsigned char byteHi = (value >> 8) & 0xff; // High Byte of result unsigned char byteLo = value & 0xff; // Low Byte of result }
Martin
Certified CVI Developer
(6,025 Views)
Thank you a lot, Martin.
This solves the problem. Seems as if I thought too much about bits'n'bytes to not see the simple way.
Bernd
(6,020 Views)
You can also do this with a union. Unions are powerful things and very useful but use them wisely as they can get confusing.
Define the union something like this:
typedef union {
short int si;
unsigned char ch[2];
} si2uchar;
Then use it be declaring a variable of type si2uchar and accessing it as either a short int or 2 element array of unsigned char by using the dotted notations like this:
si2uchar utest;
utest.si = 0x1234;
// utest.uchar[0] is now 0x12 and utest.uchar[1] is 0x34
utest.uchar[0] = 0x55;
utest.uchar[0] = 0xaa;
// utest.si is now 0x55aa
Martin Fredrickson
Test Engineer
Northrop Grumman
Advanced Systems and Products
San Diego, CA 92128
(5,979 Views)
