LabWindows/CVI
solve linear equations vs pseudoinverse memory issues
I am trying to solve a Ax = b system, and have setup my algorithm to use the LU decomposition followed by the appropriate use of the "Solve Linear Equations" VI. I then check the error output from this VI, and if there is an error I try using the "PseudoInverse Matrix" VI.
I am doing this in a loop with a progressively larger matrix for each iteration.
This works great EXCEPT for when my algorithm gets close to the maximum memory allowed (i.e. - the iteration BEFORE I get an error message stating that the VI has run out of memory).Then, although I do NOT get an error code from my "PseudoInverse Matrix" VI, the values output from this VI are complete garbage (really really large values).
Has anyone come across a similar issue before? Is there a way around this? i.e. - I would like to know when/if the  "PseudoInverse Matrix" VI will not provide valuable data output so I can stop my algorithm the iteration beforehand.
Thanks!
(3,546 Views)
You are referring to VIs, is this a LabView question?
If so, you are in the wrong forum, this is Labwindows/CVI, the C language IDE forum.
Martin Fredrickson
Test Engineer
Northrop Grumman
Advanced Systems and Products
San Diego, CA 92128
(3,545 Views)
