LabWindows/CVI
How to create a new file without using the file select pop up in CVI
I need to find a function for CVI that automatically creates a new file that i can write to. I will not be able to select a file when i am running the application, so i need to set up the program so that he application is automatically created.
(3,647 Views)
FileSelectPopup() function does not creates the file, it is just a way to have the user select a path. If you don;t need the user to select a path just call OpenFile(,,,) and pass the path that you create. After the open you can use ReadFile or WriteFile functions to read the file as usual.
You may need the Fmt(,,) functio to create the path at run time, you can create a string and append the file extension and them pass that as the path.
Let me know if you have any questions.
Juan Carlos
N.I.
(3,649 Views)
hi,
the open/create file vi accepts file name and path type and not a string,
i want to assign file name through a program,
please tell me how to do it,
if you can attach an example it will be halpful
thank you
akash
(3,492 Views)
In case you need to build a complex pathname and don't want problems in formatting backslashes or so, you can recursively use MakePathname function to create your file/path name: this example creates the variable <file> that holds the pathname for C:\TEMP\TEST.TXT file.
char file[MAX_PATHNAME_LEN];
MakePathname ("c:", "temp", file);
MakePathname (file, "test.txt", file);
(3,472 Views)
