Try this out
1- Create an empty project
2- Open the fp in CVI
3- With the fp open, go to Options >> Create DLL Project. This will ask you to save a project and then load it up.
4- Chose Release or Debug configuration from the Build menu item, and then build the DLL from the same Build menu item.
5- If you want to change the name of the DLL, go to Build >> Target Settings.
I hope this helps
Bilal Durrani
NI
