LabWindows/CVI
How to design Digital CRO using Labwindows/CVI
1.Requiremnt is simple i have to read 10 volt Analog signal I will pass to ADC.
2.how to plot analog waveform in CVI GUI from ADC in Labwindows/CVI
(3,171 Views)
With NI DAQmx? Have you already tried "Find Examples..." in the Help menu or the Welcome Page?
/* Nothing past this point should fail if the code is working as intended */
(3,111 Views)
for Reference attached image
(3,089 Views)
I need alorithm,i will only load panle and plot the waveform. im not looking daqmx solution.
(3,087 Views)
If not DAQmx, how are you intending to read the analog signal? Where is the ADC located and how is interfaced to the PC?
(3,061 Views)
