LabWindows/CVI
How to do HTTP POST in LabWindows CVI
I would like to do a HTTP POST in LabWindows CVI. Do you have any suggestion?
I have successfully done that in Visual Studio using C++ with the libcurl library.
But, when I was trying to migrate my libcurl into CVI, it does not compile.
Please advise.
Thank you,
(7,484 Views)
I do not think we have any HTTP libraries, but here is an example of making HTTP Requests using .NET Controllers in LabWindows/CVI.
Hope it helps!
Anjelica W.
Product Marketing Manager
FlexLogger and TestStand
(7,461 Views)
I've done this in CVI using the telnet library and manually putting together the appropiate commands to send to the web server.  It's a bit tedious but I made it work.
(7,453 Views)
Hello ,
I have some difficulties to make it work, can you send me you source please.
Thanks a lot.
Rgds
(6,942 Views)
Hi Sebi,
To make an HTTP POST with labwindows you have to use ConnectToTCPServer (with port number = 80 ) to connect to your server.
And then ClientTCPWrite/ClientTCPRead to send your POST request and read back answer.
Here is a sample POST request to be sent by ClientTCPWrite :
POST /yourpath HTTP/1.1
User-Agent: yourtool
Content-Type: text/plain
Content-Length: 20
some data to be sent
Stef
Labwindows/CVI user since version 4.0
(6,879 Views)
