How to generate a checksum number of a char[256]
I have to generate a checksum number of a char[256] before send it trough a TCP/IP port, and check it on the other side (remote PC) when I receive it. Did anybody knows how to do it in a easy way.
Many thanks in advance.
Xavier
xcaparros@capatest.com
Image Hosted by ImageShack.us
Message 1 of 11
(6,442 Views)
Here's a function that generates a "Internet" style checksum on a string. Runs all OK under CVI.
Bob Hayes
USHORT CheckSum(UCHAR *pszString) {
// Create checksum for a string. Note that ANSI C specifies the
// overflow behavior of unsigned integer types.
USHORT sum = 0;
while (*pszString) sum += *pszString++;
return ~sum; // 1's complement checksum
} // end, CheckSum
Message 2 of 11
(6,452 Views)
I attach an abstract from a document by Angelantoni Industrie (climatic chambers constructor) that describes the communications protocol between a PC and a Siemens PLC. The protocol extensively uses CRC calculation to assure goodness of messages. There is a description of the CRC calculation method and examples in C and Visual Basic to use the functions for calculating the CRC to transmit and checking the CRC received.
This examples follows the MODBUS protocol specifications.
Roberto.
Message 3 of 11
(6,452 Views)
Hi Roberto,
Would you happen to have the entire document from angelantoni? I've just 'inherited' one of their chambers and want to find a way of controlling it via the RS232... so any more info that you may have would be appreciated...
Many thanks
email
Message 4 of 11
(6,452 Views)
Some years ago You tried to control an angelantoni climate
chamber via LABView. As we’re experiencing some problems using LABview to set
the target temperatur, I wondered if You had any success.
Message 5 of 11
(5,877 Views)
Hi, it's possible that you are confusing me with some other poster here, since I never used LabVIEW to interface such equipments.
Which problems are you experiencing? If you can add some details maybe I can assist you a little.
Message 6 of 11
(5,870 Views)
slaine, I have sent you the documentation you asked me.
Message 7 of 11
(5,869 Views)
OOPs. Sorry You're right. I mismatched that.
Thanks anyway.
Markus
Message 8 of 11
(5,862 Views)
slaine, I received a "user unknown" error while posting you the documentation: please send me an email so that I can reply sending you the informations you asked. My address is in my profile.
Message 9 of 11
(5,818 Views)
Roberto, did you notice the date of slaine's request? I doubt that he is still waiting for the information, after nearly six years Smiley Happy
JR
Message 10 of 11
(5,811 Views)
