LabWindows/CVI
How to get StepGetUniqueStepId of a step during run time
Not sure how to get expected handle for this funcation call.
I am trying to call this during a post step
seqContextCVI is the CVI AxtiveX automation handle.
 iStatus = TS_StepGetUniqueStepId (seqContextCVI, &sErrorInfo, &pPath);
I get -2147467262 for the status.  What is the error?  Where would I find this error code defintion?
(3,080 Views)
Hi goslow,
You probably get the error because the first parameter you passed to the function is not pointing to a step.
You input the whole sequence context.
You should specify which step you are trying to access.
From this function call you provided, this is not clear.
The ErrnoToTSError function translates the error code to TS_Err_OperationFailed.
S. Eren BALCI
IMESTEK
(3,057 Views)
