LabWindows/CVI
How to get the errorlevel of a DOS Command Line programm in a CVI App
Hi
I have to start a DOS Command Line Programm from my CVI App with
LaunchExecutable() or System(). The DOS Programm ends with its state
(OK, NotOk, ...) returned to the shell. How can I read this error
state in the CVI App ???
I'm using CVI 5.5.
Oliver
(4,246 Views)
Sorry, can't do it, not with those functions. You would have to use Windows SDK programming. I think the function CreateProcessEx in the SDK is what you would want to use.
Best Regards,
Chris Matthews
(4,246 Views)
I found an example of how to do it with SDK programming. It's shown below. This example runs the process, waits for it to finish, then checks the exit code. It assumes an exit code of 0 is success.
static int RunBatchFile (char *path)
PROCESS_INFORMATION pInfo;
STARTUPINFO sInfo;
int success = FALSE, exitCode, cursor;
cursor = GetWaitCursorState();
SetWaitCursor (1);
memset (&sInfo, 0, sizeof (sInfo));
sInfo.wShowWindow = LE_SHOWNORMAL;
sInfo.dwFlags = STARTF_USESHOWWINDOW;
sInfo.cb = sizeof (sInfo);
if (CreateProcess (NULL, path, NULL, NULL, FALSE, 0, NULL, NULL, &sInfo, &pInfo) == 0)
goto Error;
if (WaitForSingleObject (pInfo.hProcess, 6 * 60 * 60 * 1000) != WAIT_OBJECT_0) // 6 hour timeout
goto Error;
GetExitCodeProcess (pInfo.hProcess, &exitCode);
if (exitCode != 0) // assumes that these batch files return 0 on success
goto Error;
success = TRUE;
Error:
SetWaitCursor (cursor);
if (pInfo.hProcess)
CloseHandle (pInfo.hProcess);
return success;
(4,246 Views)
It works fine that way..
Thanks a lot
Oliver
(4,246 Views)
