Here is one way to get around this
1- Uninstall the previous version of CVI
2- Use the attach reg (i added the txt extention so I can upload it) file to add a CVI 7.1 InstallDir key. I have modified it to point to ..\Program Files\NI\CVI. You can view the file in a text editor and modify it as you like. This basically makes the installer think that CVI is already installed and the current location is the location mentioned above.
3- Run the 7.1.1 installer and now it should default to the path in the InstallDir key.
I've reported this issue, so you won't need to do this for next release of CVI.
I dont think you will run into the same thing with TestStand. If you do, let me know.
I hope this helps
Bilal Durrani
NI
