LabWindows/CVI
SQL Toolkit - Getting output from stored procedure
I am unable to get an output or return value from a stored procedure in SQL Server 2000 using LW/CVI 6.0.
I looked at all the examples. The KB and forums had users with similar problems with LabView but I have not seen any posts using LW/CVI. Input parameters work OK, it's just trying to retrieve an output. I am using DBCreateParamxxxx instead of DBRefreshParams because input parameters didn't seem to work with the latter function.
(3,667 Views)
Please try the attached example. If you still have the same issues please feel free to post again to let us know.
Scott Y
NI
(3,658 Views)
Scott,
Thanks for the info. It helped greatly and I can now read outputs from my stored procedure!
It turns out the problem was with my stored procedure. The examples I saw from Microsoft used either the SET or SELECT to set the output variable but not both together. Using the SET then the SELECT statements worked.
Very grateful,
Art
(3,652 Views)
