LabWindows/CVI
How to launch/show panel without suing blocking functions like RunUserInterface()?
Good afternoon,
I developed a DLL in LabWindows/CVI containing new step types that i use in TestStand. One of those step types (in running mode, post substep) launches a panel which must remain active through all the test sequence allowing the normal procedure of steps after calling that specific step.
I cannot use a blocking function like RunUserInterface() since it doesn't return until QuitUserInterface() is called.
Alejandro
(3,127 Views)
Accepted by AlePinto
A couple of ideas:
  • Set up a loop that calls ProcessSystemEvents and then sleeps.
  • Create a function in a new thread using CmtScheduleThreadPoolFunction and call RunUserInterface from this thread.
(3,102 Views)
Thanks for your response richferrara!
Finally, i implemented a secondary thread which runs RunUserInterface function as you mention but, to finish its execution programmatically or by pressing "Quit" button of a panel loaded in secondary thread, i used PostDeferredCallToThread to call QuitUserInterface in that secondary thread, whose ID is got by CmtGetCurrentThreadID.
Alejandro
(3,022 Views)
