LabWindows/CVI
How to open a FileDialog to select a folder
My software need to ask a user to select a folder in a explorer, or to create and return the new folder.
I found that "FileSelectPopup(ex)" can select only a file.
By other way the "Filebrowser" lib that open a browser in a tree control seem a very old look.
I found that "OpenFileDialog" of windows SDK or "IFileDialog" COM object could select a folder.
Is it possible to use one of them from CVI, or to create a instrument with "Tools... Create a active X controler" ?
Is this another way to show the folders, create one, and return the new path ?
(5,523 Views)
Accepted by french_eddy
What about DirSelectPopupEx to select a folder?
The full version of CVI comes with the Win32 SDK so in this case you can also use the native Windows function.
(5,520 Views)
