LabWindows/CVI
How to programmably disable a panel callback?
I don't want the panel callback to be called when I am calling ProcessSystemEvents (). Is there any way to do that?
Alternatively, is there any way to make CVI only response some specifc events such as clicking some specific buttons?
Thanks.
(3,311 Views)
To disable a panel callback, you can use InstallPanelCallback (panel, 0, 0); The same could be done in control callbacks with InstallCtrlCallback (panel, control, 0, 0);Alla panel and control callbacks must be reisntalled when you need them again.
Alternatively (maybe it's simpler), you could manage a global variable that is raised when entering your special section of code and in panel and control callbacks return immediately if that variable is on.
(3,299 Views)
