LabWindows/CVI
Is there a function that gives my current path?
I want to create an exe Labview file for someone else to use it, and I want the program to know in which folder he put it. Is there a way to know that?
(3,150 Views)
Yould use Current vi's path (file I/O >> Fiel constants palette) and pass the output to StripPath.vi: the output from this is the path to the directory the VI is in. This works both when running as a VI inside LV and when compiled in an executable.
An alternative solution can be to use an application property node (Application control palette) selecting Application as a class and Application:Directory path as the property: this solution returns the path to LabVIEW.exe when running inside LV environment and path of youe EXE when the application is compiled.
(3,148 Views)
Thanks Roberto, this is exactly what I needed.
(3,097 Views)
