How to programmatically scroll a table
How to translate this LabVIEW VI to CVI ?
George Zou
(5,638 Views)
Accepted by zou
The nearest equivalent should be SetActiveTableCell ().
(5,626 Views)
That VI actually make the specified cell row up to be the top-left visible cell.
Got help from NI AE.
         SetCtrlAttribute(panel, PANEL_TABLE, ATTR_FIRST_VISIBLE_ROW, cell.y);
works in the following code:
  cell.x = 2;
  cell.y = 1;
  err = GetTableCellFromValue (panel, PANEL_TABLE, cell, MakeRect(1,2,NR-1,1), &cell, VAL_COLUMN_MAJOR, VAL_CELL_STRING, VAL_CHAR,selected);
  if ( ( err < 0) || ( (cell.x == 0) && (cell.y == 0)  ) )
   //not found
   cell.x = 2;
   cell.y = 1;
  MessagePopup("","");
  err = SetCtrlAttribute(panel, PANEL_TABLE, ATTR_FIRST_VISIBLE_ROW, cell.y);
  if (err < 0)
   MessagePopup("Error", "Setting first visible row in table.");
  SetTableCellRangeAttribute(panel, PANEL_TABLE, MakeRect(cell.y, 2, 1, NC-1), ATTR_TEXT_BGCOLOR, VAL_CYAN);
However, if I comment out MessagePopup("","");
then it won't work.
George Zou
(5,623 Views)
Not exactly what I expected.  But works too.
Doesn't have to be top row.  As long as visible, works for me.
Thanks.
George Zou
(5,618 Views)
