LabWindows/CVI
How to programmatically scroll a table
How to translate this LabVIEW VI to CVI ?
George Zou
(5,652 Views)
Accepted by topic author zou
The nearest equivalent should be SetActiveTableCell ().
(5,640 Views)
That VI actually make the specified cell row up to be the top-left visible cell.
Got help from NI AE.
         SetCtrlAttribute(panel, PANEL_TABLE, ATTR_FIRST_VISIBLE_ROW, cell.y);
works in the following code:
  cell.x = 2;
  cell.y = 1;
  err = GetTableCellFromValue (panel, PANEL_TABLE, cell, MakeRect(1,2,NR-1,1), &cell, VAL_COLUMN_MAJOR, VAL_CELL_STRING, VAL_CHAR,selected);
  if ( ( err < 0) || ( (cell.x == 0) && (cell.y == 0)  ) )
   //not found
   cell.x = 2;
   cell.y = 1;
  MessagePopup("","");
  err = SetCtrlAttribute(panel, PANEL_TABLE, ATTR_FIRST_VISIBLE_ROW, cell.y);
  if (err < 0)
   MessagePopup("Error", "Setting first visible row in table.");
  SetTableCellRangeAttribute(panel, PANEL_TABLE, MakeRect(cell.y, 2, 1, NC-1), ATTR_TEXT_BGCOLOR, VAL_CYAN);
However, if I comment out MessagePopup("","");
then it won't work.
George Zou
(5,637 Views)
Not exactly what I expected.  But works too.
Doesn't have to be top row.  As long as visible, works for me.
Thanks.
George Zou
(5,632 Views)
