LabWindows/CVI
How to programmatically set the selected radio button on a radio buttons group
Good day, I have another question for you.
How can I programmatically set as selected a specifically radio button on a Radio Buttons Group? I think this is very simple but i can't find a solution.
Thank you in advance.
(4,876 Views)
Accepted by FM82
You can use the SetActiveCtrl function
(4,855 Views)
Accepted by FM82
If you're using toolslib\custctrl\radioGroup.fp, then use Radio_SetMarkedOption.
If you're using toolslib\custctrl\radioBtnGrp.fp, then use RadioBG_SetMarkedOption or RadioBG_SetMarkedOptionCtrl.
Hope this helps.
(4,841 Views)
Thanks for the help!
(4,830 Views)
