LabWindows/CVI
How to put the display into the screen saver mode in LabWindows/CVI?
Does anyone know how to put the display into the screen saver mode using LabWindows/CVI?
TIA,
nqn
(3,495 Views)
Try this:
LaunchExecutable ("C:\\WINDOWS\\system32\\yourScreenSaver.scr //s");
If you want to activate the defined screen saver in the system instead of a fixed one, you need to retrieve first the path to the screen saver executable:
RegReadString (REGKEY_HKCU, "Control Panel\\Desktop", "SCRNSAVE.EXE", file, MAX_PATHNAME_LEN, &stringSize);
(3,474 Views)
Hello Roberto,
just out of curiousity: what's the "//s" doing in the command?
(3,459 Views)
The "/s" command-line option executes the screen saver. If omitted, the screen saver settings dialog box is presented on the screen. See this MSDN entry for detaiils.
(3,438 Views)
