LabWindows/CVI
How to read the data from the txt file and store them in two-dimensional array using CVI
Hi !
The following is the data stored in my txt file.
04-12-2011  14:27:13     外部交流电压 220, 主回路电压 27.368,主回路电流 0.088, 工作电池箱 1,工作电池组 0, 工作状态 4
04-12-2011  14:27:23     外部交流电压 219, 主回路电压 27.369,主回路电流 0.1, 工作电池箱 1,工作电池组 0, 工作状态 4
04-12-2011  14:27:33     外部交流电压 220, 主回路电压 27.35,主回路电流 0.06, 工作电池箱 1,工作电池组 0, 工作状态 4
04-12-2011  14:27:43     外部交流电压 219, 主回路电压 27.35,主回路电流 0.094, 工作电池箱 1,工作电池组 0, 工作状态 4
04-12-2011  14:27:53     外部交流电压 219, 主回路电压 27.355,主回路电流 0.073, 工作电池箱 1,工作电池组 0, 工作状态 4
04-12-2011  14:28:03     外部交流电压 218, 主回路电压 27.347,主回路电流 0.099, 工作电池箱 1,工作电池组 0, 工作状态 4
Now I want to read "外部交流电压" "主回路电压" "主回路电流" datas according to the time sequence and restore them in three arrarys: :data[i][6]、data[i][7]、data[i][8]   And them plot them on a graph separately . Year,month,date ,hour and time is separately stored in these arrars.
data[i][0] 、data[i][1]、 data[i][2] 、data[i][3]、data[i][4]
However,I don't know how to realize it.
Expecting you to help me. The attachment is the file which I want to read datas from.
Thank you very much.
Best regards.
xiepei
I wouldn't care success or failure,for I will only struggle ahead as long as I have been destined to the distance.
(4,030 Views)
the attachment
(4,029 Views)
Hi xiepei,
What is the difference to this post ? For me it appears to be the same formatting/scanning issue...
Because I can't read chinese characters, there is little to understand (and little to help)...
And finally, this forum is mostly meant for questions specific to CVI, not about C in general. Did you have a look at the sample arrayfile provided with CVI? It treats a cloesely related subject and already might give you some ideas.
(4,022 Views)
Moreover it also appears to be identical to this thread
(4,010 Views)
Hi !
http://http://forums.ni.com/t5/LabWindows-CVI/Read-datas-of-txt-file-according-to-the-list-using-CVI...
Because I didn't find the best solution.It works not well in that post.I am thinking another way to read the txt file and store them in two-dimensional array using CVI.However,I have no idea about realizing it. So I have put this post here,expecting someone  to help me.
It's my mistake,I should not use Chinese characters here. I will modify it.
(3,989 Views)
Hi
I could not get any help when I put the question to that thread.So it appears here,expecting someone giving me some help.
I'll see to it and will not appear the  identical post.
Regards.
xiepei
(3,987 Views)
Hi !
I could not edit the post.Therefor,I correct the post here.
04-12-2011  14:27:13     220,  27.368,  0.088,   1,   0,   4
04-12-2011  14:27:23     219,  27.369,  0.1,      1,   0,   4
04-12-2011  14:27:33     220,  27.35,    0.06,    1,   0,   4
04-12-2011  14:27:43     219,  27.35,    0.094,   1,  0,   4
04-12-2011  14:27:53     219,  27.355,  0.073,   1,  0,   4
04-12-2011  14:28:03     218,  27.347,  0.099,   1,  0,   4
04-12-2011  14:28:13     220,  27.355,  0.068,   1,  0,   4
04-12-2011  14:28:23     219,  27.354,  0.076,   1,  0,   4
04-12-2011  14:28:33     219,  27.35,    0.104,   1,  0,   4
04-12-2011  14:30:18     221,  27.362,  0.094,   1,  0,   4
04-12-2011  14:30:28     221,  27.352,  0.082,   1,  0,   4
I want to read the first seven column data(e.g.220),the first eight column data(27.368),and the first nine column data(0.088) according to time sequence and restore them in three arrarys,such as data[i][6]  data[i][7] data[i][8].Then I can plot them separately on three Graph controls.
The front five columns datas,namely,year,month,date,hour,minute (e.g.04\12\2011\14\30) will be stored separately in these five arrarys.data[i][0]  data[i][1] data[i][2] data[i][3] data[i][4]
(3,983 Views)
