LabWindows/CVI
the method CW3DGraphLib__DCWGraph3DPlot3DCurve does not work
Hello
I have problem with 3D graph, I want draw only simple curve, here is my code
 data1[0]=1;
data1[1]=8;
data1[2]=9;
data1[3]=6;
data2[0]=9;
data2[1]=2;
data2[2]=4;
data2[3]=5;
data3[0]=6;
data3[1]=2;
data3[2]=9;
data3[3]=8;
    VARIANT xArray,yArray,zArray;
GetObjHandleFromActiveXCtrl (panelHandle,PANEL_CWGRAPH3D , &graphHandle); CW3DGraphLib__DCWGraph3DGetPlots (graphHandle, NULL, &plotsHandle); CW3DGraphLib_CWPlots3DItem (plotsHandle, NULL, CA_VariantInt(1),&plotHandle);
CA_VariantSet1DArray (&xArray, CAVT_DOUBLE, 4, &data1);
CA_VariantSet1DArray (&yArray, CAVT_DOUBLE, 4, &data2);
CA_VariantSet1DArray (&zArray, CAVT_DOUBLE, 4, &data3);
CW3DGraphLib__DCWGraph3DPlot3DCurve (plotHandle, NULL, xArray, yArray, zArray, CA_DEFAULT_VAL);
Thank you for help
(4,777 Views)
Dear Honzik,
in order to do what you want to do, you need to replace:
with a function
CW3DGraphLib_CWPlots3DAdd
I can visualize it in LabVIEW:
Hope this helps.
If you have more problems, you can have a look at the following forum threads:
http://forums.ni.com/t5/LabWindows-CVI/Adding-plot-in-3D-graph/m-p/1230695
http://forums.ni.com/t5/LabWindows-CVI/problem-with-cw3dgraph/td-p/475090
(4,764 Views)
Thank you for your answer
but if I replace it, it doesn't draw anything. I have simply task, draw some points into defined positions x,y,z. Plot surface works but there is some 2D array and I need 3D.
Jan Prudil
(4,759 Views)
Dear Jan,
it should work in this configuration. Could you post your project files here?
As I wrote before, I used the same ActiveX functions in LabVIEW and it worked.
(4,745 Views)
here is my project, it is very simple only for testing 3D graph
thank you
(4,739 Views)
Dear Jan,
please try:
                CW3DGraphLib_CWPlots3DAdd (plotsHandle, NULL,&plotHandle);
                double data1[4];
                double data2[4];
                double data3[4];
                data1[0]=1;
                data1[1]=8;
                data1[2]=9;
                data1[3]=6;
                data2[0]=9;
                data2[1]=2;
                data2[2]=4;
                data2[3]=5;
                data3[0]=6;
                data3[1]=2;
                data3[2]=9;
                data3[3]=8;
                ERRORINFO i;
                CW3DGraphLib_CWPlot3D_CIPlot3DCurve (plotHandle, NULL, xArray, yArray, zArray, CA_DEFAULT_VAL);
                CA_VariantClear (&xArray);
                CA_VariantClear (&yArray);
                CA_VariantClear (&zArray);
(4,725 Views)
Thank you, it works.
(4,719 Views)
