LabWindows/CVI
How to resolve conflict between toolbox.h and extcode.h?
Hi!
Very simple question.
I would like to call LabVIEW-generated DLL from CVI GUI Application.
So, I have generate lets say "SharedLib.DLL" in LabVIEW and got SharedLib.lib, and SharedLib.h files.
SharedLib.h  included into CVI project as well as *.lib file.
The problem, that in SharedLib.h file the first line is
#include "extcode.h"
and in CVI I have
#include "toolbox.h"
Now I've got following trouble by compiling:
 UI Application.c - 3 errors
  "toolbox.h"(504,67)   Redeclaration of 'Pin' with different calling convention, previously declared at extcode.h:445.
  "toolbox.h"(506,76)   Redeclaration of 'SwapBlock' with different calling convention, previously declared at extcode.h:619.
  "toolbox.h"(633,141)   Redeclaration of 'BinSearch' with different calling convention, previously declared at extcode.h:554.
Otherwise if I will change the order of SharedLib.h and toolbox.h, then a lot of other errors coming:
 UI Application.c - 20 errors, 6 warnings
  "extcode.h"(443,45)   syntax error; found '<' expecting ')'.
  "extcode.h"(443,45)   Missing identifier.
... <skipped>
  "extcode.h"(445,53)   Redeclaration of 'Pin' with different calling convention, previously declared at toolbox.h:504.
  "extcode.h"(554,94)   Redeclaration of 'BinSearch' with different calling convention, previously declared at toolbox.h:633.
I can remove extcode.h from Sharedlib.h, but this file recreated every time by DLL build.
Of course, I can create my own header for the library, but auto-generated header is a very convenient for me.
So, the question is - how can I resolve conflict between excode.h and toolbox.h?
Thank you in advance,
Andrey.
(3,494 Views)
Ups, sorry,
I have similar topic myself:
CVI fails to compile extcode.h (labview include file) and any toolbox fp file in CVI
regards,
Andrey.
(3,490 Views)
