LabWindows/CVI
undocumented CVI function
I found this funtction inside CVI panel library:
  SetOwnerForNextCreatedWindow(int HWnd);
but no help or info about that.
Could you anybody help me?
Luigi Magni (System Engineer - CTA)
(3,549 Views)
Hello Luigi,
Although a prototype for this function exists in userint.h, this function is not really part of the User Interface Library, and that's why there is no documentation for it. It exists only for internal use in TestStand operator interfaces.
Luis
(3,507 Views)
Hello Luigi,
I'd like to get more informations about the function you're using in order to help you.
Where did you find it? I couldn't locate it in CVI and also by doing a research in Google I didn't receive any result.
Andrea N.
Principal Applications Engineer - Semiconductor EMEA
National Instruments Italy
Certified LabVIEW Architect - Certified TestStand Architect
(3,504 Views)
