How to run CVI program from command line
Hi! For memory debugging purposes, I need to start my program from the command line. I know what my current working directory should be. I go there in the command prompt and run >myprogram.exe. The result is an error in call to LoadAnsiPanel (File not found: myprogram.uir, Error code -94).
Why can't LoadPanelAnsi find the file even though the cwd is the same? The same happens if I start the .exe file from the file explorer.
(2,821 Views)
Accepted by guybrush_threepwood
Two options:
1. Unless stated otherwise in LoadPanel, .UIR files must be located in application folder: is thefilepresent where the application expects to find it?
2. In Build >> Target Settings mark "Embed Project .UIRs" checkbox: this way .UIR files are no longer needed as informations on the panels and controls are included in the executable
(2,818 Views)
Thanks for answering!
1. It is located at "../" (adjusted for in the code), but that shouldn't be the problem since I make sure that I use the same working directory as when I run the program via the CVI IDE, right?
2. Solved my problem! Thanks!
(2,811 Views)
I really don't know, I never tried putting .UIRs in a directory other than the application one.
But I see in the help for the function:
You can use a complete pathname or a simple filename for filename. If the name is a simple filename that contains no directory path, the file is loaded from the directory that contains the executable.
Now I don't know how to interpret this sentence, as this does not mention a relative pathname. I wonder for example if relative pathnames are to be intended with reference to the application folder or to the working directoy.
Anyway, l'm gladto heve helpedyou.
(2,790 Views)
