LabWindows/CVI
How to send an array with ClientTCPWrite
I would like to send a big array (a picture in fact) to another computer via a TCP server.
I already use the TCP Support Library to send data to a software running on a different computer and it's working well.
So I did the same thing with a integer array and it doesn't work. I used the sample of Labwindows's help to send this array, and only the first part of the array is received.
I don't understand.
int SendImage(BYTE *lDataToWrite)
   	DWORD 	dwWaitResult;
	int bytesToWrite;
	int bytesWritten;
	int messageSize;
	if (giTCPConnected1 == TRUE)
		bytesToWrite = messageSize = sizeof(BYTE)*WIDTH*HEIGHT;
		while (bytesToWrite > 0)
			bytesWritten = ClientTCPWrite (giTcpConnection1, &lDataToWrite[messageSize - bytesToWrite], bytesToWrite, 0);
			bytesToWrite -= bytesWritten;
	return(ERROR_NO_ERROR);
	WORD Tab[WIDTH*HEIGHT];
	SendImage(Tab);
int CVICALLBACK ReceiveTcpMsg(unsigned hdl, int event, int error, void *callbackData) {
	int		iDataSize;
	int 	i,j;
	DWORD 	dwWaitResult;
	int bytesToRead;
	int bytesRead;
	switch (event)
		case TCP_CONNECT:
			giTcpConnection = hdl;
			giLineConnected = TRUE;
			break;
		case TCP_DATAREADY:
			// Read tcp/ip data
			bytesToRead = messageSize = sizeof(WORD)*WIDTH*HEIGHT;
			while (bytesToRead > 0)
				bytesRead = ClientTCPRead (giTcpConnection, &Tab2[messageSize - bytesToRead], bytesToRead, 0);
				bytesToRead -= bytesRead;
			break;
		case TCP_DISCONNECT:
		  	giLineConnected = FALSE;
			break;
	return (0);
Is someone has already used these functions with a big data size ?
Or do you know other methods to send an array to an other software ?
Thank you for your help.
Benjamin
(4,612 Views)
Accepted by Benjamin.J
When I had to perform something similar to your task I have found more confortable to split the dispatch in several smaller pieces (say more or less 3-4k bytes each).
This gave me also the possibility to monitor ethe process and eventually to interrupt it.
(4,608 Views)
Thank you for your answer.
I tried to split data in pieces of 3kB and it's seem working. I will finish to test it but it's in good way. Thank you.
Benjamin
(4,576 Views)
