LabWindows/CVI
How to send serial signal to DAC (LabWindow/CVI)
I am beginner with LabWindows/CVI.
I would like to set the referent voltage using DAC 7611 sending them serial signal with NI DAQmx 6229.
Can someone explain me how can I do that with LabWindows/CVI (version 7.1)?
Thanks in advance
Jovo
(2,947 Views)
You will have to use the digital out lines of the 6229 to do this. Here you can find an example that shows you how to do this:
The example is for digital input, but this is very similar to digital output.
Hope this helps!
(2,915 Views)
