Home
Community
Discussion Forums
Most Active Software Boards
LabWindows/CVI
Topic
LabWindows/CVI
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How to send serial signal to DAC (LabWindow/CVI)
Jovo
Member
03-24-2006
04:13 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I am beginner with LabWindows/CVI.
I would like to set the referent voltage using DAC 7611 sending them serial signal with NI DAQmx 6229.
Can someone explain me how can I do that with LabWindows/CVI (version 7.1)?
Thanks in advance
Jovo
0
Kudos
Message
1
of 2
(2,938 Views)
Reply
Re: How to send serial signal to DAC (LabWindow/CVI)
Andre_Saller
Active Participant
03-28-2006
03:44 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
You will have to use the digital out lines of the 6229 to do this. Here you can find an example that shows you how to do this:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=FEF2721D78802175E0340003BA7CCD71&p_...
The example is for digital input, but this is very similar to digital output.
Hope this helps!
0
Kudos
Message
2
of 2
(2,906 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
