LabWindows/CVI
How to set default struct allocation size
How can I set the default size that CVI uses to allocate structs? Right now I think it is set to 8 bytes and I want it to be one byte.
(3,197 Views)
The default structure packing is done with pragma pack statements. CVI supports these statements so you can insert
#pragma pack 1
at the top of your code to ensure 1 byte boundary packaging of structures.
Best Regards,
Chris Matthews
(3,197 Views)
